local-as (bgp-neighbor-config)
      Configures this neighbor‘s local AS number
        - Service Platforms — NX9500, NX9600
    Syntax
      local-as <1-4294967295> {no-prepend}
    Parameters
              | local-as <1-4294967295> {no-prepend} |
              Configures the local AS number
                  - <1-4292967295> – Specify a value from 1 - 4294967295.
                      - no-prepend – Optional. Select to enable. When enabled, the local AS number
                        is not prepended to route updates from eBGP peers. AS numbers are prepended
                        to route updates by default.
      nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#local-as 20 no-prepend
      nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
   enforce-multihop
    Related Commands
              | no (bgp-neighbor-config) |
              Removes the local AS number. And also reverts prepending
                of AS numbers to default (allows prepending). |
